LS3 cam sprocket 4x vs. ls2 2x
I am doing an L92 swap into my T/A and am going to use Lingerfelter's 58x to 24x converter box, the question I have is I have an LS2 2x cam sprocket(Part # 12576407), but this is a 2x sprocket. The conversion box converts the crank sig from 58x to 24x and the cam sig from 4x to 1x. I guess the ls3's are a 4x sig, which is what I need. Is there a 4x sprocket that also has the 3 bolt mount? The ls3 sprocket is a 1 bolt mount. Lingenfelter told me I need the LS3 4x set up. I wanted a cam that uses a 3 bolt mount, not the one bolt. Will an LS7 cam sprocket fit my needs? Thanks.
12586481.....which i think is correct......
