Can I run 11:1 on 91 octane?
Old Mar 16, 2009 | 02:20 AM
sschoeffler's Avatar
Default Can I run 11:1 on 91 octane?
Well exactly how high can I go with the stock computer on a 408 stroker?
Old Mar 16, 2009 | 02:42 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i have run as high as 12:1+ compression on 91 octane, but it depends on alt of different variables, like dynamic compression (cam choice), and of course tune. but 11.1 is a nice safe number for street car running 91 octane
Old Mar 16, 2009 | 06:53 AM
SweetS10V8's Avatar
Sure it will run, will it be optimal? No....
You'll have to be conservative on timing.
Old Mar 16, 2009 | 04:03 PM
Ragtop 99's Avatar
Ryne is correct. There's not enough data to say that it will be suboptimal. He hasn't specified the heads or cam that is being used. I'd go for it.
Old Mar 16, 2009 | 04:21 PM
Sammyboy's Avatar
I think there is a general rule of 11.5:1 ....will be safe for pump gas
Old Mar 19, 2009 | 08:05 AM
CodeRed2000SS's Avatar
thats what i go by. you will be fine with 11.1
Old Mar 19, 2009 | 02:54 PM
RoDan's Avatar
I run 12:1 on 93 if that gives you an idea.
Old Mar 19, 2009 | 05:49 PM
383lt1impala's Avatar
That's the compression the ls7 has and it runs on 91 with no problem in cali.
Old Mar 19, 2009 | 06:19 PM
NemeSS's Avatar
what cam specs?
what is your dcr with your cam?
Old Mar 19, 2009 | 06:22 PM
quintenk's Avatar
11:1 is stock on an ls2 I wouldn't worry at all. I'm at like 12.3 and have no problem running it on 91. Just cam it accordingly
Old Mar 21, 2009 | 12:35 AM
LSGunZ28's Avatar
Whoever said, You should be fine needs to reword what they said..
He should Generally be fine, but the most important things id say is the DCR and how much timing its gonna be running..
Old Mar 21, 2009 | 02:34 AM
67Ranger's Avatar
As long as its tuned by someone who knows what they are doing, it will run fine. We put right around 11.5:1 in all of our street car motors, and it always works great. There are other factors like cam, heads, intake, etc, but 11:1 is fine for basically anything.
Old Mar 21, 2009 | 03:12 AM
Gregory's Avatar
I am running 12.5:1 static compression, 8.67:1 dynamic compression, 30+ degrees of timing, 93 octane or E85, 1 degree of knock reduction maximum with both.
You can do it!
I believe the LS7 has 11.0:1 static compression and must make due on 91 octane.
Old Mar 21, 2009 | 08:46 AM
Gen414's Avatar
Yeah, anything under 12:1 with teh right tune will be ok. I am running 12:1 in my setup, and plan on putting pump gas through it. No corn, just good old 93.
At the same time, you get a bad batch of fuel, or agressive with teh timing/tune....gotta pay attention. I personally think that @ 11:1, you can just about get away with anything....bad gas, agressive tune, and have no worries. Once you start getting closer to 11.5:1 and up, is when things start getting more critical.
