Valve Seals for L92 Heads
I need some new Valve Seals..mine went to ****. Anyone have a source that has good ones?
I currently have Blue ones that I got from TX Speed with my Spring Kit, I don't know what kind they are. The car sat for 6 months while I was in Iraq, now it burns Oil like a mother focker..
Installed correctly, it's incredibly rare that the Viton valve (blue) seals leak oil down the guides. An alternative seal would be the factory brown seals available through your local dealer. Just order for a 1997-2000 car or 1999-2001 truck application.
Check for oil getting pulled into the intake manifold via breathers.
Good luck and thank you for your service
Richard
Richard
might want to check the rocker studs sometimes they reach thru into the runners and if not lock tighted or sealed, oil will reach the runners. Also if ur runnin stock rockers with a big cam, you might start ******* up the v guides which can also allow oil into the runners. imo
And thank you very much for bein over there.
