Biggest cam with stock Stall
I am looking for a cam that will make the best power with my stock stall in my 05 GTO. My setup will include an LQ4 shortblock, GTP stage 2 heads milled to give me 11.03:1 compression, Edelbrock Pro-Flo intake, 1 7/8 Kooks LTs, 3" catless exhaust through Magnaflow mufflers, 3.91 rear gears. Please don't tell me that changing the stall would be better or this or that....I KNOW!! I just don't want to do it. Any suggestions are appreciated.
236/238 .601/.605 113+3 should be about the limit
edit: This cam should be about all you can handle with the stock converter
Everything mentioned so far is still to big for a stock stall on any auto car. A 228 on a 114 or more lsa maybe...maybe. I'd say no bigger than a 220 on a 114. Look into a custom grind that would suit your need the best since you want to stay stock stall Pat G would give you a great cam spec that would be perfect for that set-up. One question if your going H/C/I anyways why not a stall converter seems kinda of waste to me IMO only. Why not a 2800 converter that would open the doors up to a lot more cams like 224s 228s and the likes and give you a very nice package with the CR you are planning to run and the heads and intake you'd like to use. Your gears suit a bigger duration cam anyways.
LS1Tech Premium Sponsor
Agreed, that's the largest we typically recommend for a stock convertor car as well. Any larger and it wants to push through the brakes and gets too sluggish.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Same driveability between the two, but about 7hp at the crank more from the XER lobes. I'd go .581" any day between the two, stock convertor or not.
__________________
