ptv clearance on a milled 243 head.
Old 08-20-2009, 10:05 PM
redgto4u's Avatar
Default ptv clearance on a milled 243 head.
Hey all,
I have an 05 gto with a 234/236 .600/.600 112lsa cam. I am going to get a set of tea 2.5 243 heads. Would you guys recommend milling these at all for some more power/compression? I don't want to worry about the valve hitting the pistons though.
Old 08-21-2009, 09:19 AM
redgto4u's Avatar
anyone...?
Old 08-21-2009, 09:43 AM
2001ws6-500hp's Avatar
what cc are the heads? 64?
Old 08-21-2009, 09:48 AM
redgto4u's Avatar
Yes the ones I am looking at now are patriot 64cc heads. I understand that patriot doesn't mill the head to add compression. But I might be able to get a set of patriot stage 3 64cc heads on here. I need to make sure they will work first!
Old 09-08-2009, 05:24 PM
redgto4u's Avatar
ok so after thinking about and talking to some local pro's I am going with the TEA 2.5 ls6 heads unmilled. Since I am spraying a 150 shot on top of things what head gaskets should I use. Stock or cometic? Thickness?
Old 09-08-2009, 10:22 PM
SOMbitch's Avatar
With the bigger valves I think you will have to run gm mls to stay in the safe range and only a small mill (.010)....112LSA straight up or advanced any...I think you will have to measure especially if advanced.....
Quick Reply: ptv clearance on a milled 243 head.
