6.2 max bore
6.2 max bore
What is the max bore you can go on the sleeves in a alum 6.2 Sticking with stock stroke and would like go bigger on the bore. 4.125 would be great
I have a scratch in one cyl that .005 will not take out.
I am very impressed with the way these things are built. plus the 96lb block is hard to belive.
Thanks
Tim
Thanks
Tim
4.100 safley, the problem is that the block is built around the sleeves, so they are not centered. if they were centerd you might get a 4.125 bore out of them. rule of them is minium thickness of .080 for a sleeve
wiesco custom pistons are $110 a piece. sleeves on average are $100 per sleeve installing price (that doesnt count purchasing price of the sleeve.). so $880 for pistons and $1500 plus for sleeves. if you call dimnd, wiesco, keith black, they usually have pistons for most applications.
With a 4.100 bore this means we can slap on some LS7 heads on the L92/LS3 blocks right?
LS1Tech Premium Sponsor
We have 4.100" bore L92 engines sitting here at the shop with LS7 heads on them!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I probably even have the pistons in stock!!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
