LS3 Crate Engine with no oil pressure
I really need some help here. I have a brand new LS376/480. I have tried 3 gauges (two electrical and one mechanical) and can't get an oil pressure reading. I removed the gauge and cranked the engine and nothing. I removed the oil filter (which was full of oil) and cranked the engine. Not a drop came out. After talking with GM and hearing about some problems with the o-ring and/or the relief valve spring, I dropped the pan. Before going any further, I thought I would zip tie a plastic bag to the pick up tube and give it a couple cranks. It wanted to suck the bag inside out. It looks like the pump is actually working. What do I need to look for? Any help would be greatly appreciated.
Mike
Mike
I had to pull a plug on the side of the motor(drivers side front)and use a vacuum pump to pull oil through the oil pump to prime it. Once I got oil there it had oil pressure after that. I had previously stuck a oil funnel in the oil pressure port where the oil pressure switch normally goes and gravity fed oil for days thinking it would prime it the other way.
Found the problem. The o-ring on the oil tube pickup was pinched. Luckily, the pinched part didn't break off and I have to fish it out of the system. Per GM, this is a known problem with the LS3 engine. You would think GM would have fixed it by now.
The following users liked this post:
Jimbo1367 (05-01-2021)
Mike
Mike
When the new engine comes in, I’d run a pan baffle and a pick up brace ( EGM-500) from IMPROVED RACING for a pc. of mind. I’d reseal(R&R) the pick-up tube to make sure it’s done correctly. I’d also prime/pressurize the oiling system until oil comes out all of the rockers BEFORE ever turning the motor over.
a lot of people may think that’s a wast of time, I considering it a investment .
DualQuadDave (05-01-2021)
Block the oil tube pickup and pressurize the LF engine oil galley (16Mx1.5) to 20psi and watch oil (or listen if using air) pour out the relief bypass hole back to pan area.
