Arp LS7 Rod Bolts
Arp LS7 Rod Bolts
Well, in case many of you have not seen the Arp website in a while, they just released thier LS7 Rod bolts. They come with their new Pro Torque lubricant as well. So here is the ARP Update and they are ready to GO!!! As with all arp bolts, they still recommend that honing be excersized. Use that at your own discretion.
Here is our link!!
Here is our link!!
Katech bolts are $199 plus you have to buy their special lubricant the dow molykote for a little extra. These come with the lubricant for $189.
They just released them in november, unless you have assembled alot of engines since then using both bolts, then you have not used these specific bolts. The regular arp bolts are alot less expensive than the katechs. People will use either for their own reasons.
