oiling system parts comatibility help
I'm having a tough time getting a solid oiling setup put together. For background, i have an lq9 block at the machine shop being bored .030 over to a 408 with callies crank, callies rods, and diamond pistons. For a cam I have a thunder racing t-rex with ls1 timing set.
As for the oiling system, im having a tough time getting a combo put together that is compatible. On hand I have a texas speed ported ls6 oil pump, ls2 oil pan and windage tray, and an ls2 screen and pickup. Is this going to work?
thanks!
thanks!
thanks man. Do you know the sponsor who makes that collar? I'm going to need that, the bolts for the collar, and bolts for the oil pump itself. I'm building this from scratch and its a pain getting all the hardware too
Moderator
Sure:
New Pick up Tube girdle for LSX engine from BRP Hotrods
The size for the bolt is listed in that post, I would think a regular bolt from a hardware store will do.
