LSX-LS3 heads info
LSX-LS3 heads info
Does anyone have any info on these heads? I am going to run a 408 LSX block motor and I need a 6 bolt head that will fit this motor. Does anybody have a cnc program for these?
Unless you know someone who matters at GM you'll only be able to get these heads as complete assemblies. There are two versions to fit L92/LS3 engines. The LS3 version comes with hollow intake and sodium exhaut valves the LS9 version comes with ti intake and sodium exhaust valves.
Our Stage 2 and Stage 3 programs will fit. The Stage 3's will need the larger 2.20" intake valve and at the moment they're only available with solid stems.
Give us a call if you have any questions.
Richard
Richard
