LS7 install ChevyII Wiring & oil pan
First have issues with the wiring from GM.
The kit is completely assembled , I guess there assumption is there is no firewall! (I should know, I used to work for the "A")
Any way, what firewall bulkhead pin adapters have anyone used.
FIRST! no way in hell am I using the one from Painless.
Any ideas? I have found a few, just searching for good ideas!
Second, I have oil pan issues with the dry sump.
I have called ATS and also e-mailed them with no response fo specifications yet on there pan.
Any other known options for the dry sump LS7 engine?
Thanks
guys.
Al
![](http://img855.imageshack.us/img855/6050/domsls7026a.jpg)
![](http://img196.imageshack.us/img196/5434/domsls7007a.jpg)
![](http://img94.imageshack.us/img94/8910/domsls7024a.jpg)
![](http://img853.imageshack.us/img853/7742/domsls7019a.jpg)
Clearance issues with pan.
![](http://img200.imageshack.us/img200/3523/domsls7010a.jpg)
![](http://img856.imageshack.us/img856/8939/domsls7006a.jpg)
Thanks for the garment there GM, guess i will shrink the plug in hot water to make it fit! Dumb "A" !
Hole for the plug will be larger than the garment.
![](http://img860.imageshack.us/img860/7742/domsls7019a.jpg)
1967 ChevyII Chassis Works front clip, LS7 & 4L85E Supermatic transmission.
Thanks
guys.
Al
