Gen IV block + Gen III heads-----Which head bolts?
Old 03-23-2010, 11:52 PM
Berz28's Avatar
Default Gen IV block + Gen III heads-----Which head bolts?
I have a gen Iv iron 6.0 that i am putting my gen III heads on out of my 98 ls1. wich head bolts do i need? the short gen IV ones or the longer Gen III ones?
Thanks
-Mike
Old 03-24-2010, 12:07 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
You need the ones that match the block. If its a Gen IV block, then use the Gen IV style headbolts which are all the "medium" length as compared to the Gen III LS1 block.
Old 03-24-2010, 01:20 AM
LS1MCSS's Avatar
If you're not sure if they are all the same length, stick a piece of wire down in the bolt holes. Then you will know for sure if they are all the same depth.
