lsx engine ( need advice )
Old 04-18-2010, 03:26 PM
habibtoday's Avatar
Default lsx engine ( need advice )
Hi Guys
i need your advice on my friend's project :
before he used on his corvette c4:
stock ls7 engine + High lift cam + Q.F 1050 carb. + GM intake
(1/4 mile ET =9.6)
Currently his project is :
lsx 454 + stock ls7 heads + High lift cam + GM intake + Q.F 1050 carb
compression around 11.5
(1/4 mile ET =10.2)
finally 10.2 ?? is it logical ??
Old 04-18-2010, 04:35 PM
8 second mod
Noyzee's Avatar
lots of things come to play. more motor etc doesnt meen better et's. if the combo isnt working together right, cam installed wrong, tune up off, cam not speced good with heads, lots of things. to much cam, could be colapsing lifters and loosing power. lots of things could do this
Old 04-18-2010, 04:57 PM
habibtoday's Avatar
i think you are near from the problem
the cam wich he used is custom made especially made for the previous engine wich is stock ls7
can you advice me wich the best cam for this spec.
Old 04-18-2010, 07:25 PM
KCS
Moderator
KCS's Avatar
What are his 60' times and MPH?
Old 04-19-2010, 11:43 AM
habibtoday's Avatar
60 feet = 1.422
330 = 4.211
660 = 6.531
kmh = 170.55
990 = 8.521
1320 = 10.208
kmh = 213.62
these are time slip's information
Old 04-19-2010, 03:00 PM
KCS
Moderator
KCS's Avatar
What were they with the 9.6 1/4 mile? Need to compare.
Old 04-19-2010, 03:54 PM
habibtoday's Avatar
i think
60 feet = 1.33
1/4 mile et = 9.6
kmh = 224
Old 04-19-2010, 08:34 PM
fuel's Avatar
the car needs to go on a dyno....and the tune mabe wrong
Old 04-19-2010, 08:53 PM
KCS
Moderator
KCS's Avatar
Originally Posted by habibtoday
i think
60 feet = 1.33
330 =
660 =
kmh =
990 =
1/4 mile et = 9.6
kmh = 224
vs.
60 feet = 1.422
330 = 4.211
660 = 6.531
kmh = 170.55
990 = 8.521
1320 = 10.208
kmh = 213.62
Right off the bat, it's odd that you lost ~10KMH with a larger engine! You should have gained trap speed, not lost any. I'd get the engine looked over, you've lost power with a 454 compared to the 427...
Quick Reply: lsx engine ( need advice )
