LQ4/LQ9 Oil Cooler
Old 04-18-2011, 02:04 AM
WS64Mula's Avatar
Default LQ4/LQ9 Oil Cooler
To run an oil cooler on the LQ4/LQ9 blocks, does the sandwich adapter need to be installed or is the block tapped for it? If it is tapped for it; where is it tapped at? Thanks
Ben
Old 04-21-2011, 06:26 AM
CamaroSS22's Avatar
There is a boss on the side of the oil pan that can be removed and there are two -an fittings underneath. Its used for the oil temperature sensor on the corvettes.
Quick Reply: LQ4/LQ9 Oil Cooler
