501rwhp & 474rwtq from 6.0 block topped with LS3
A 2007 car with LS2 block with LS3 heads with the following:
Please see the link video:
http://www.facebook.com/#!/photo.php?v=204179212944889
Seems the LS3 head do have sweet zone...
Thanks
- LS2 6.0 Liter Aluminum block.
- LS3 Intake Manifold ported.
- TB 92mm.
- LS3 Cylinder Heads (None ported, however it is polished).
- Kooks headers.
- Magnaflow cat back.
- Upgraged push rods.
- OME fuel pump.
- Cold Air Intake.
- Custom Cam.
- Catch Can & Breather.
Thanks
I wish to know
I saw it in the local thread in the middle east with a link in the facebook
about the camshaft, it is a costum but he didn't provide detailed about the specification.
As about the torque convertor, where I have no information about it
I will try to find more information if avilabe in the facebook
Thanks
Thanks
Sounds as though you are dismissing this as being true.
Just because you spent 40k, doesn't mean someone cant do it cheaper.
Just sayin.
Those numbers are possible with a tight convertor and the smaller cubes making less torque. i can't see the graph at work so only guessing. We are making similar numbers with a combo like that. Our heads have been ported and it has a decent sized cam.
I beleive the custom spec cam should be something like 227/239 with 114 LSA
The hp numbers could be right but the torque you mentioned is almost impossible to achieve with a 6.0 engine and A4 transmission.
Even Patrick G couldn't reach that level of torque with AFR 230 heads.
By the way Patrick G's car have similar engine of the Caprice and Lumina SS.
https://ls1tech.com/forums/dynamomet...k-results.html
I recal a discussion about RPM shop in other forum that managed to perfom almost around 480rwtq from 6.0 block with LS3 heads and costum cam with manual trans...
