Lq4 compression
Lq4 compression
So I picked up a 04 lq4 and 4l80 the other day has been dotting for awhile so I put it on my stand and did a compression test with not good results. Anyway squirted a lil atf into cylinders let soak and rolled engine over a few times then took compression again. MUCH BETTER RESULTS. Now im at 140 psi on 6 cyl and 150 on 2 cyl. Now is this good ok bad. Im looking to do a truck manifold turbo setup thanx
05, 150, calculator, check, compresion, compression, comprrssion, cylender, cylinder, good, lq4, nunbers, psi, test, turbo, whats
