Found LS3 complete motor, built - Want opinions on if this is a good deal.
Old 01-26-2012, 11:17 PM
tonyturbo42's Avatar
Question Found LS3 complete motor, built - Want opinions on if this is a good deal.
Ok here are the specs. I can get the complete engine for $5500. Claims 8000 miles on it. Let me know if this is a good deal please. I'm new to LS world so go easy on me. Going into my 67 El - Camino with a TT set up.
Shortblock
Diamond 11553 pistons with coated skirts -9:1 with 70 cc heads
Built on new LS3 block
Callies Compstar forged 3.62 stroke crank, 6.2 L
Callies Compstar rods
Clevite bearings
Cloyes timing set
Manley pushrods
LS7 Lifters
Heads
Ported/polished LS3 heads
Comp 921 dual springs
Manley stainless valves
CAM- 224/224 .610/.601 114 LSA
Injectors - 75lb/hr Racetronix fuel injectors
Intake - Stock LS3
Throttle Body - LS3
Wiring harness with all sensors
Thanks, Tony
Old 01-26-2012, 11:31 PM
litle88's Avatar
It sounds good, I mean it has all the good parts from piston to crank. And it's set up for your TT with lower compression.
Old 01-26-2012, 11:53 PM
itsslow98's Avatar
My first question would be who built the motor and did the machine work, and where are the invoices proving it.
Id also ask what power level it saw and how it was used.
I just dont know I could buy a built motor and be 100% confident. Id rather buy a built shortblock from a vendor and go that route. That way you know exactly how it is and how the tune will be from the first startup.
Old 01-27-2012, 12:16 AM
Thank you guys for the advice. I agree I'm a little questionable about buying a built engine. The good thing is he does have all the receipts and its from a reputable shop that is close to my own shop. I did plan on having the machine shop check it out, make sure all is well and prob do a hone and new rings. Just seems like I can save a lot of parts hunting by buying a complete engine over a short block.
Quick Reply: Found LS3 complete motor, built - Want opinions on if this is a good deal.
