Comp Cams Truion Upgrade for LS7
Old 04-02-2012, 12:16 AM
1999FirehawkLS1's Avatar
Default Comp Cams Truion Upgrade for LS7
Went to install my rockers on my LS7 heads and what ya know the bolts the kit comes with are way to long.....Comp should note this in there sale adds of these thing cause it says for LS Series engines.....so u would think all of them by the way it sounds
Old 04-02-2012, 11:26 AM
LSxChevelle's Avatar
Really? I know it says they work for LS1/2/3/7...do LS7 heads use different bolts than say a LS3?
Old 04-02-2012, 06:44 PM
veee8's Avatar
Yes, they use a shorter bolt because the rocker stand is built into the head. You can reuse the factory bolts on the comp trunion. Just takes a thin wall socket.
Old 04-02-2012, 09:57 PM
I never had the factory ones but lone behold lowes has the same dam socket head cap screw as come w comps kit lol
Quick Reply: Comp Cams Truion Upgrade for LS7
