Cam upgrade in L76/L77 DOD removal
HI im doing a cam upgrade in my L77 series 2 Holden ss
for people who may be interested I have made a list of all parts needed to remove DOD and cam upgrade
i am using Lunati high lift 219/223 6.25" lift lobe sep 12deg camshaft kit for street use.
GM genuine parts you will need:
.lifter buckets 12595365 x4
.lifter bucket bolts 12551163 x4
.water pump gasket 12630223 x2
.front crank seal 12585673 x1
.front cover gasket 12633904 x1
.valley plate 12570471 x1
.valley plate gasket 12610141 x1
.valley plate Orings 12610160 x8
.dirty air tube 12594779 x1
.block off bung 12579145 x1
.head gaskets 12610046 x2
.ls2 chain dampener 12588670 x1
.coolant 5l 1#92145527 x1
ARP:
.arp crank balance bolt 234-2503 x1
.arp head bolt kit 134-3610 x1pk
COMP CAMS:
.comp cams 3 bolt lock plate kit for ls camshaft 5461
LUNATI:
.camshaft 60516
.lifters 72910
.push rods 7050-16
.valve spring set 73925-16
.spring seats 86695-16
.spring retainers 75793-16
.valve lock collets 77123-16
.timing chain set 95533 (might not fit might require single chain)
i think i have covered everything excepted spark plugs and oil.
i will be reusing some seals like intake manifold seals and header gaskets.
ARP:
COMP CAMS:
LUNATI:
.camshaft 60516
.lifters 72910
.push rods 7050-16
