Is there a easy way to remove valve seals from TFS heads?
Old 10-27-2012, 05:50 PM
WADDISME's Avatar
Default Is there a easy way to remove valve seals from TFS heads?
Repl valve springs and doing seals also. TFS have the ridged guides. Just curious if there is a trick to getting the seals off and on. Pulled one off, but it was a lot of work.
Quick Reply: Is there a easy way to remove valve seals from TFS heads?
