LS2 Oil Pump
LS2 Oil Pump
I am in the middle of doing the DOD delete and adding a 3 bolt EPS cam to my L76 motor. I am going to replace the timing gear as well as oil pump. I am curious as to what pump to run. Is there any one brand/type to run and any to stay away from?
Should I use a standard volume pump, the original pump is a hi-pressure pump for the DOD and has got to go!
Thanks
Mike
Thanks
Mike
