RHS Pro Elite 291cc/69cc Heads LS7
Hi Folks
I would like to hear from you guys if anyone has installed these RHS Pro Elite 291cc heads on LS7 .
Pro Elite CNC Machined/Ported Rectangular Port Aluminum Heads for LS7 (4.125Bore minimum).
-291cc Intake Runners,69cc Combustion Chambers.
-Valves: Manley 2.200" Intake & 1.615" .
-Standard LS 6-bolt head design is compatible with the advanced RHS®LS Race and popular GM LSX Blocks.
-100% CNC-machined runners optimize volume, atomization and velocity.
-Improved clamping capacity greatly head gasket retention in high horsepower and boosted applications have .750" Thick deck surface integrity.
-Reinforced solid rocker rail increases rigidity and stability; 355T6 aluminum withstands race conditions
.400" Raised rail works with aftermarket rockers; .100" raised exhaust port allows use of stock and aftermarket manifolds
Thanks in Advance !
Thanks in Advance !
They look and sound like nice heads I was wandering if anyone had any experience with them too. The intake ports are HUGE though. Kinda makes me wonder how they would work on a street engine.
yea , they have raised intake port ,exhuast port & rocker arms for extra clearance .
i am comparing them to : Mast Inline Valve PXR 12 Degree 4.125"-4.200" 6-Bolt CNC
http://www.mastmotorsports.com/2010/...p?cat=Cylinder Heads - Bare&id=351
who is PXR? They look like MMS'S MOZEZ heads.
The RHS LS7 heads are nice pieces. However, the intake runners aren't as large as it may seem at a glance. They are 291cc intake runners, but they are also raised runner heads. They have an extended face that adds runner length and volume. This allows a standard FAST LS7 intake (as well as other LS7 type intakes) to be used. For this reason, when you compare the cylinder heads, you should look carefully at runner CSA.
440ci at 12:1
The head you are talking about.
A solid roller cam i did thats roughly 254/271@.050.
Holley Hi Ram intake...
Made 773@8000 and it hadnt peaked yet... owner got nervous and wouldnt let the dyno guy go 8500.
Cam wasnt intended to peak that high.
With a tweak to the camshaft, intake porting and some more tuning that motor will make 800-820 hp na pretty easy we think.
Im using a set of these on a turbocharged build. They appear to be a quality casting.
Uploaded with ImageShack.us
wow nice setup
it seems RHS heads is the way to go .
