Lifters - Comp Pro Mag vs LS7
Old 03-11-2013, 05:52 PM
2001CamaroGuy's Avatar
Default Lifters - Comp Pro Mag vs LS7
What's the advantages/disadvantages to each (LS7 vs Comp 875-16 Pro Magnum lifters)? I have a brand new set of Comp Pro Mags that I was given, however I'm trying to decide if I should use them or go with LS7 lifters. I will be using the factory non-adjustable rockers and doing something like a TR Torquer 3 cam and PRC dual springs. 7000RPM max.
Old 03-11-2013, 06:25 PM
Tainted's Avatar
Anything is an upgrade over the ls7s just about.
Old 03-11-2013, 06:38 PM
litle88's Avatar
Here is what I would personally go with.
http://www.briantooleyracing.com/btr...r-lifters.html
Old 03-11-2013, 10:24 PM
I thought people were really liking the LS7 lifters. What's wrong with them?
As I said, I have brand new Comp pro mags. Any reason to not use these?
Old 03-11-2013, 10:27 PM
Tainted's Avatar
Ls7 lifters just cant keep up with aftermarket cam lobes and high stress loads. That have a high failure rate whether its because of install error, quality control, or just not cut out for the task.
For a factory lifter they are decent but they leave a lot to be desired.
Old 03-11-2013, 11:00 PM
Super Hulk Smash
JakeFusion's Avatar
The 875s "Comp R" are okay, but they have a very narrow preload window. They are more trouble than they are worth, but are an upgrade over the LS7s.
Old 03-14-2013, 07:36 AM
MertezWS6's Avatar
Bump! I'm a believer in doing it once and doing it right and I'm in the hunt for lifters. litle88 I like those lifters you showed, I assume they will fit in LS2 lifter trays? Anyone else have any preference on lifters if they wont go with LS7's????
Old 03-14-2013, 08:04 AM
Realcanuk's Avatar
I went with Morel 5206's from Brian Tooley. I wanted to get rid of those lifter trays.
Old 03-14-2013, 08:43 AM
litle88's Avatar
^^^I did that too!^^^
Old 03-14-2013, 05:11 PM
87silverbullet's Avatar
^^^^Smart man right there!
Old 03-14-2013, 06:35 PM
ss performance's Avatar
How are the Comp 850-16?
Quick Reply: Lifters - Comp Pro Mag vs LS7
