lingenfelter timing box???
swapping my old ls1 out for a ls3 crate engine i got with my discount for working at a gm dealership. i noticed lingenfelter makes a conversion box for the 58x to 24x timing. anyone out there running it. if its reliable i would rather just run it then pull the crank and void my warranty on the engine
A few of my friends have one cause they are Ls2's and 3's. they have ha no issues. Just make sure it's placed in a ventilated spot.
Just make sure you don't change your timing gear. It must also be a 4x cam sprocket or it won't work.
Good luck.
Good luck.
