Project YOLO: The Quest for 100 HP per Liter
Old 12-17-2013, 10:25 PM
427zm's Avatar
Default Project YOLO: The Quest for 100 HP per Liter
Ok, so the build thread starts! My car is a C5Z,
and after a head swap and Fast 92 install earlier this year (a Pat G EPS lobed cam was already in it when I purchased it), I realized that the 430 wheel I had wasn't going to cut it, I needed MORE POWA! So, being that it's a Vette, and packaging is not great for turbos, I had 2 options, either centri blower (with an A&A kit or an ECS kit) or go big cubed NA motor build. While considering both options this year, I have had the opportunity to see some of my Vette brethren locally go both big NA build or centri FI build. Witnessing these builds ahead some real guiding light on the path I chose. By around September, it was a no brainer for me. After seeing one of my buds with his recent FI build struggle for 9 months to keep his car running, there was no doubt for me I was going NA all the way, and that meant getting bigger. Substantially bigger.
So, I'm beginning my build thread for my ERL 434. It took me a long time deliberating over my choices to end of with a 434, but being that my goal was 570+ wheel NA, a 402 or 418 wasn't going to cut it. At least, not without a huge cam, that made peaky power.
So, 434 cubic inches is 7.1 liters, and as the title states, I'm looking to get 100 HP per liter NA. This means 710 flywheel, which will mean roughly 600 wheel. For my practicality, I will be attempting to do this with pump gas (93 here in Texas) and not going Donkey D for my cam! My cam won't be small either, but it won't have 50* of overlap or anything.
First things first: yesterday I said bye bye to my old LS6! It'll do the new owner good, it was a strong, reliable, motor for what it was.
Old 12-17-2013, 10:28 PM
sick_tight's Avatar
awesome! cant wait to see this in person. any idea when youll be all finished?
if you ever need a hand wrenching i woudnt mind coming out by you. i learn more hands on
Old 12-17-2013, 10:41 PM
427zm's Avatar
Fun began a few weeks back, when parts started to arrive:
Found this already painted gloss black LS7 intake. Perfect for top side!
Along with the intake came the already ported TB!
Found some Brand New 52# injectors for a deal I couldn't pass up, so I grabbed them, and the mini time adapters as well.
Can't forget my fuel rail! Here in all its glory with my alternator and TB about to head to powder coating!
Gen IV sprocket, C5R timing chain, and damper.
Cometic 4.160 head gaskets. Obviously, you can't use the factory bore size head gasket with the larger sleeves!
Melling 10296 High Pressure, High Volume Oil Pump.
All together now! From Katech valve covers, to a new starter, the new motor is getting a bunch of new stuff!
Old 12-17-2013, 10:45 PM
427zm's Avatar
Yep, everything should be finished up in Early January. I'm not wrenching most of it, it's being put together locally.
Old 12-17-2013, 11:00 PM
427zm's Avatar
My ERL shortblock should be arriving sometime in early January. Fun times are soon to come!
Old 12-17-2013, 11:30 PM
Super Hulk Smash
JakeFusion's Avatar
LS7 topend can make 650rwhp with the added bore... and you can do it with probably 25-30 degrees of overlap. Which sounds like a lot until you realize it's a 434...
What heads? I'd get the LS7 manifold ported and put some WCCH LS7s with the CHE Rockers.
Old 12-18-2013, 07:25 AM
427zm's Avatar
Yep, 650 wheel is possible, but I'm not going to have that much cam in it. My manifold and TB have been ported, and my cam is going to be a 235/251 .657/.660 on a 114+2.
For heads, I'm going with stock LS7's that are currently being ported by Frankenstein Racing Heads. QMS, whose doing the install, uses mainly WCCH for port work, but has also used FRH, and has seen FRH ported heads gain 20hp over WCCH ported LS7's. Due to the increased bore, and running flat tops with valve reliefs, I'm keeping the chamber size at the stock 70cc. Bore in my case here is adding compression, and it's going to be right on the verge of pump gas DCR, with a static CR around 11.8:1. I need cam overlap to bleed off compression. My rockers are factory 1.8's with the comp trunnion upgrade.
On the Vette forum there are a few people running the Katech K501, which spec wise is identical to the cam I'm going with currently, it's just cut on a 113 straight, no advance. The results from this cam on the few LS7's on the Vette forum have been good when paired ported WCCH's heads. They have ranged from 580-600 wheel. So I should be able to obtain my goal with the couple of added cubes.
Old 12-18-2013, 08:40 AM
KCS
Moderator
KCS's Avatar
Just FYI, overlap does not bleed off compression. You're thinking of IVC.
600whp shouldn't be too difficult with 434ci and LS7 heads. The RHS heads look to be an awesome value and could probably be put together for less money than OEM LS7's. They use raised intake and exhaust ports, but you can still utilize the OEM style manifolds (stock, LS7, etc). Plus you don't have to worry about the exhaust valve/guide issues with the OEM heads.
Old 12-18-2013, 08:46 AM
427zm's Avatar
Looking back, on my heads, I'd have probably gone with RHS or PRC 285's for the money I have in mine. I'm dang close money wise to having fully decked out Mast 285's! Now, it's too late, they're being built, and the money has been spent.
Old 12-18-2013, 12:59 PM
Super Hulk Smash
JakeFusion's Avatar
Chris Frank will do awesome work. I usually throw Richard out there for the value his heads bring. I would look at the CHE upgrade tho... offset 1.8:1 GM rockers like to puke their guts.
Old 12-18-2013, 01:47 PM
427zm's Avatar
Yep, I'm looking forward to getting the heads back from Chris. He's not inexpensive, but from the results QMS has shown with his port work, it should be worth the extra cash. I'll get flow data with them and put it up here for sure. As for the rockers, they are factory, but they have the comp trunnion upgrade kit in them. They'll be no worry of them puking GM needle bearings all over the motor!
Old 12-18-2013, 02:34 PM
KCS
Moderator
KCS's Avatar
Well, at least with the guy that's porting them you shouldn't be disappointed. I always hear good things about him.
Old 12-18-2013, 02:41 PM
427zm's Avatar
I hope so. I haven't heard many people on the street running Chris's porting, but that's a good thing to me. "Group think" is really prevalent on forums, and at times it drives business to select guys/shops/tuners just because someone else did such and such. It's not always bad, but at times it can be. I can assure you, it isn't inexpensive work, so I sure hope its a producer.
Old 12-18-2013, 07:46 PM
LPE 403's Avatar
And what would that combo consist of again?
OP....sounds like it'll be a handful in that Vette. Sub'd.....
Old 12-18-2013, 08:06 PM
427zm's Avatar
I'm looking forward to it! My hope is this setup will push me north of 190 next year at the Tx mile.
Old 12-19-2013, 10:17 PM
dekan513's Avatar
sweet, this is gonna be awesome
Old 12-20-2013, 07:40 AM
HioSSilver's Avatar
Looks like things are coming together.
Old 12-20-2013, 08:10 AM
427zm's Avatar
I sure hope so. I'm attempting to do it right the first time, so I don't have to do it twice
The engine bay is empty and waiting.....
Old 12-20-2013, 08:50 PM
D9HP's Avatar
Tagging along - looks great. I bet that pile of parts is exciting to see all the time!
Old 12-20-2013, 08:52 PM
427zm's Avatar
Yes, and no. Yes, because of the anticipation of what it'll be! No, because of the anticipation of what it isn't yet. Soon. Very soon.
Quick Reply: Project YOLO: The Quest for 100 HP per Liter
