Ls2 Rotating Assembly In LQ4/LQ9 Block
I was looking into putting a full ls2 rotating assembly into a lq4 block. Would there be any complications on just swapping it straight over? I would get new bearings and new rings and the lq4 block would get a hone. Is there any modifications to get this done or is it possible? And if its possible with the lq4 would it be the same with the lq9? Im looking to get the higher compression without going with the expensive ls2 aluminum block.
I did some searches and found the crank is the same stroke and the block bore is the same I just want to make sure there isn't a slight difference im missing.
Sounds good. But you want to mic the cylinders and pistons.
I'm looking for a 6.0 aluminum block for my 408 stroker build.
Definitely measure or send everything into the machine shop to see if everything will play well..If it's the complete LS2 rotating assembly that's one thing but if you're using a 3.622 throw crank from another engine you should probably get the rotating assembly balanced.
The following users liked this post:
Che70velle (08-03-2024)
