.040 head gaskets?
Oh Oh...
I know I'm to be critiqued but if I was you I would must definitely check piston deck high before you get the .040 head gasket for a 4.100 bore block.
Is cutting it really close, with piston in top dead center push down the outer side of the piston and measure how much the high side sticks out of the bore, your finding may change your mind.
