Rockers for big lift
Hey guys. Ive got a 232/242 115 cam with .665 lift both sides in my l92 headed 408. Running lunati dual sprungs. What rockers should I be looking at? Money isnt an issue but just want the most reliable option. Would go uograded factory but they wont play nice with such big lift correct?
Links to online store would be good. Im from Australia and dont know of too many american online shops. Thanks
I am not running as much lift as you are but started my solid roller valve train build with Yella Terra ultralight adjustable rockers. I didn't like them, they were difficult to fit rocker covers with the adjustable version and I disliked the amount of lash they would change when hot. I installed a set of Jesel adjustable rockers - I can't say enough good about the Jesel rocker set up. Fits like a glove, adjusts easy and is much more solid when installed. My recommendation is Jesel.
These are made by T&D machine for Comp cams and are of excellent quality and will take anything you can throw at them and when service is needed you send them to T&D machine and they will replace needed parts and ship back only for the cost of the replacement parts (the last time I checked) you may want to call and ask.
http://www.jegs.com/i/COMP-Cams/249/...oductId=870985
