Asa
Asa
Need some help! I hav a LS cam, that I believe is the asa cam, 226/236 525/525 110. The only number stamped on the cam is 267A. Can anybody verify if this is the asa cam. Thanks an god bless
There are several threads here if you search..seems to be some decent circumstantial evidence that you are correct. Two of the threads are here:
https://ls1tech.com/forums/generatio...t-screwed.html
https://ls1tech.com/forums/generatio...e-asa-cam.html
Good luck.
Good luck.
