alright New here and new to big blocks
Hey all, My names Mike.
I am new to building old engines and have limited experiance to building newer stuff....
I have search everywheres and there is an overwelming amount of information on different set ups that i have no clue where to begin..
I am hoping the pros on this site could help me out assuming i am even in the correct forum.
I have a 454 from a late 80's camper in my 94 Ford f150 It runs and behaves flawlessly as is.. I just want more power!!!
The engine is completly stock with the RV cam and PP heads
the truck has 3.08 gears which i think work well with the engine and a turbo 400 trans that is also stock from the same camper.
What i am looking for is 400-450 crank HP which should be easy enough with a big block!
I really dont want to spend a lot of money on pistons and such, I am hoping i can get near that 450 mark by adding the correct cam, intake manifold and maybe swapping the 236 heads out for another stock head..
I can get a set of 3964290 heads Which if i am understanding what i have research would up my compression from around 8 to 1 to almost 9 to 1, Is this correct?
If these heads will work better then the PP heads what cam would people recomend? Im looking to Tow occasionly and mostly just have some fun with it on the weekends... Besides BIG BLOCKS sound Awesome
I really have done a bunch of research but there is just so much info ESP. about cam selection that my head hurts with numbers
Please i hope you guys can steer me in the right direction
Mike, you want to post in this forum:
https://ls1tech.com/forums/small-blo...y-specific-92/
The 454 you see guys posting about in here is a large-bore/stroke LS-based motor and really is a small block for all practical purposes. Late-model apples to your (BBC) orange.
Since I'm already posting, PP heads most likely refers to (P)orted and (P)olished heads. This is generic for any head that has been worked over by smoothing intake and exhaust ports and bowls and then polishing the exhaust side so you can flow more air and fuel in and out of the motor.
You'll never make any decent power with 8:1 compression unless you slap a turbo or supercharger on so you're on the right track there. You might want to try to get closer to 10:1 if you can as every bit helps.
Good luck in the BBC forum.
im sorry lol...Thanks for the replies. im not very familar with chevy engines at all actually so sorry for the confusion and thanks for pointing me in the right direction...
What i do know about the 454 is that The way i am and many others seem to use PP. It would stand for the Peanut Port heads that came on a 454 built for towing..
Again thanks for the help!
I do have plans to put a lq4 6.0 In my jeep rock crawler hopefully this winter so maybe ill be around and get some advice on that
