Driven Racing LS30 oil from SDPC
Old 10-27-2014, 07:41 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Default Driven Racing LS30 oil from SDPC
We have in stock what we consider to be one of the best oils for your modern engine. Previously Joe Gibbs Driven Racing oil and now known as Driven Racing Oil, this oil comes recommended from quite a few top builders in the LS world. We, as well as quite a few other builders include Driven break-in oil with all of our built shortblocks, and when you change to synthetic after the break-in period we recommend this oil, LS30 5w-30 Synthetic. We have been stocking and using this oil exclusively for several years and have had zero issues and we are now offering it to mail order customers.
Formulated Specifically For High Output GM LS Engines
Designed for high performance LS series engines, LS30 reduces oil consumption by limiting oil vaporization and foaming. It utilizes advanced mPAO synthetic base oils to reduce valve train noise and to provide high temperature and high shear protection for GM LS based engines with and without variable valve timing. LS30 delivers industry leading shear stability and HTHS bearing oil film thickness. Ideal for LS-based crate engines and supercharged LS performance engines as well as any performance engine that calls for a 5W-30 viscosity. Viscosity typical of 5W-30.
High Temp High Shear Protection
Friction Reducing Additives
Meets Demands Of VVT System
Reduced Consumption Via PCV
LS30 5w-30 Sythetic oil is 10.99 per quart.
We offer Genuine AC Delco oil filters for $4 each.
If you order 6 quarts of oil and a filter, we will include a set of 8 NGK spark plugs for free. TR5, TR55, TR6, BR7, etc. Any standard copper plug.
Order a whole case of oil (12 quarts), and a 2nd filter can be included for free.
Call 800-456-0211
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Quick Reply: Driven Racing LS30 oil from SDPC
