Motor problems!!
Old 11-07-2014, 11:45 AM
Tkrdenali34's Avatar
Default Motor problems!!
I recently purchased a 2008 Sierra Denali with the 6.2 and after I bought I took it and had a tune put on it. The guy that tuned used hp tuners and said it would take a couple hundred miles or it to re-learn the changes. After driving it a while I wanted to see what kind of changes the tune made and matted it from 15 mph or so . When it shifted there was a pause or delay before it jumped into the next gear. I called the guy that tuned it about it and he said it was trying to learn the new shift point and to just drive normal for another hundred miles or so. Well after 100 more miles I tied giving it a 0-60 and the same thing happenend it ran good until it tried to shift them paused then shifted to the next gear . After I would finally shift it sounded a little different. Then on that same run at about 65 mph the check engine light start flashing as well as service traction controll. When I come to a stop i noticed a slight knock on the motor. Took it and had it scanned and the code come back cylinder 7 misfire . Can any one help me and tell me what might have to be done to fix this ??
Old 11-07-2014, 01:08 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Check your spark plugs and wires. Especially check the porcelain on the spark plug for cracks or chips. That's the easiest thing to check when a misfire code pops up. It may just be a coincidence that it happened right after your tune.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-07-2014, 01:40 PM
Would that cause the motor to be knocking ?
Old 11-07-2014, 02:23 PM
imma_stocker's Avatar
I don't think a single cylinder misfire code is tune related. Lonnie is spot on, check the plug compared to others. Be sure the wires and connectors are on tight, not a bad idea to use dielectric grease.
Do you have a shift kit or tuned shift points? Sounds like he is leaving trans control to PCM learning. That's a great idea with BMW SMG but not so good with GM PCM.
Old 11-07-2014, 02:25 PM
Yes, it could sound like knock. It shouldn't sound like rod knock but bad spark can do a lot. If ceramic or plug tip broke off it will likely cause internal damage. Try to isolate the knock source with stethoscope or knock ears. Bottom end, top end, in the cylinder, or what.
Old 11-07-2014, 02:37 PM
I had the guy take the tune off because I was scared it was going to mess it up more because of the way it was shifting but it's defenitly a top end knock. It's not real loud but noticeable and the truck still drives but not quite as much power . The knocking doesn't get louder when I'm cruising down the road though.
Old 11-07-2014, 04:52 PM
I check the plugs and everything think is good . The sound is coming from inside the cylinder.
Old 11-07-2014, 05:16 PM
Take the valve cover off and check out your valve springs and make sure nothing is broke.
Lonnie
__________________
Old 11-07-2014, 05:39 PM
Could it be the push rod since I was running hard when it happend?
Old 11-09-2014, 04:54 PM
Could be bent pushrod or other valve train. Pop valve covers and take a look before it gets worse.
Old 11-09-2014, 06:10 PM
So am I in the clear as far as having a rod knocking and having to replace the whole motor ?
Old 11-10-2014, 10:13 AM
Nothing is ruled out until you do some investigating. We're just giving you the easiest stuff to check. A rod knock is a pretty distinctive thumping sound. Most valvetrain problems are a ticking sound. You just have to tear into it and start inspecting.
Lonnie
__________________
Old 11-11-2014, 01:44 PM
It takes a LOT of damage to need replacing the whole motor. I never jump the gun to say replace motor unless you ran without oil.
What's your redline before rev limiter kicks in? How high did you rev the motor? Stock cam, valves, retainers, pushrods, etc?
Quick Reply: Motor problems!!
