Major issues with cam install.
Engine is a ly6 with VVT delete. Installed a GT11 (215/231 .631/.644 ) cam. .650 dual spring valve springs and 7.4 pushrods. Stock lifters/stock rockers with trunion kit.
1st start up at idle offset rockers walked their needle bearings out hence the trunion kit.
2nd start up at idle ( to operating temp) after trunion kit install, broke 4 off set rocker studs. Am I missing something here? This should be a simple straight up install.
No bent pushrods.
Odd that its just the offset rockers. Is it too much pressure causing them to get in a bind?
No bent pushrods.
