Uncovered Shortblock
Old 01-11-2015, 02:10 PM
silent_soul's Avatar
Default Uncovered Shortblock
So, I took the heads off, and exhaust off my LS2. Cleaned up the coolant that spilled into the cylinders and got sidetracked. Its been sitting in my garage uncovered for like 2 months. I was planning on draining the oil out as it has mixed and draining the coolant, before I install my cam and start putting the motor back together.
Is there anything specific I should do first or make sure to do aside from new fluids?
I figure it all will be fine just draining the pan but figured I should ask before I do put it back together.
anyways thanks guys
Old 01-11-2015, 02:18 PM
Jimbo1367's Avatar
I would make sure you blow out all bolt holes.
Old 01-11-2015, 03:45 PM
KW Baraka's Avatar
OK.....so why did you take the heads off.....did you have a blown head gasket?
KW
Old 01-11-2015, 04:03 PM
LLLosingit's Avatar
KW
I would guess for a cam change?
" I was planning on draining the oil out as it has mixed and draining the coolant, before I install my cam and start putting the motor back together. "
Old 01-11-2015, 09:49 PM
The ls2 had 243 heads and I am putting ls3 heads on it to facilitate putting the lsa supercharger on. Once I get the heads from the machine shop I'll be able to put the engine back together while I wait for my refund to buy the vette/5th gen belt setup
Quick Reply: Uncovered Shortblock
