Pre-soak lifters
Pre-soak lifters
Is it really necessary to presoak lifters? Ive heard of some heating them and simmering them in oil as well. They come pre-lubed. I also plan on pre-lubing the motor before fire up since this is a fresh build.
I bought a spare crock pot just to cook lifters in. Gets all the old assembly lube out of there. If they don't spin smoothly after cooking, you know you have an issue with a new lifter before install.
What temperature do you guys set the crock pot to and how long do you soak them? Does it throw off the preload at all? I was thinking of doing this to my 2116LSR's before I get the long block together.
I did this with my 2116s. Wife decided she didn't want the turkey roaster anymore so I got a new heated parts soaker. Anyhow, I set to 200 degrees and double checked occasionally with thermometer. Won't affect preload. You aren't putting them in hot.
It doesn't hurt. I really think that the soak method is used for lifters with tight preload settings so that an accurate preload can be taken when installing. I don't think that soaking ls7 lifters would be necessary because of their high tolerance to different preload settings. But, like I said it doesn't hurt.
Many lifters come with just light rust preventative on them, they need to be cleaned and at minimum have the rollers soaked in oil to give the needle bearings protection on first startup so they don't gall or flat spot immediately. This is clearly stated in more than a few of the white sheets right from the manufacturer.
