New build stroked/sleeved 427 ls3/7 combo DYNO NUMBERS ARE IN!!! CHECK LAST PAGE
#41
LS1TECH Sponsor
Dry sleeve price and sleeve gap
Correct on the $2K for sleeving. That includes stress relief of the block, decking, boring within honing range and cutting rod notches in the bottom. Bore size range is 4.125" to 4.185" with max. recommended bore size of 4.155" for boost or nitrous.
I try to keep new 5.3 aluminum castings in stock. These are the strongest of the factory castings. Out at the moment but more on order. Current price is $725 for the casting.
I doubt the sleeves will crack without a gap. The gap is there for ease of installation by folks doing the install without the benefit of CNC which is one of LA sleeves advertising points. Without CNC it would be nearly impossible to hold the +- a half thou tolerance on bore to bore centerline that is what abutting flats require. Another problem is without flood coolant during machining the block expands due to heating of the casting during machining and will contract upon cooling closing up the bore to bore centerline. I have seen blocks six thou out of spec that were machined dry. The flats are jammed against one another forcing the sleeves out of round.
By the way, I have sleeved thousands of blocks going back to the late 1970's. Yes I have been doing this longer than most of you guys have been alive. From Jr Dragster (doing a couple for Antron Brown) to V10 Viper V12 Ferrari and everything in between. Check out Darton's web site on tech data. I wrote most of the installation guides. Check out my web site while you are at it.
The photo I attached was an LS7 aluminum block not iron.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
#46
Steve
Steve
Now are you saying blocks you sleeve will not end up with oil water mixes ?
You have to admit is much easier today then way back
#47
LS1TECH Sponsor
Coolant leakage
There is a chance of porosity in the casting that is opened up during the sleeving process. I see this more in import blocks. I have been fortunate not to have any problems with come backs due to leaks. Attention to detail, holding tolerance - knowing what that tolerance needs to be and using proper installation techniques to insure the sleeves are seated and won't drop on engine start has everything to do with the success of the installation.
I install the Darton dry liners with a sealer, Loctite 515 on the lower area of the bore to help guard against leaks. The sleeves are made with grooves in the lower body which act as virtual o rings with the Loctite. This also doubles to help keep oil from migrating up between the block and sleeve from the crankcase. Even then I highly recommend three GM coolant system sealing tablets be put in the radiator of any sleeved block as insurance against leaks.
Steve
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
#48
KIWIKID, i read your article and while i see you did fill your gaps with epoxy that doesnt seem like that was your problem if i read it correct.. you had issues with the cometic gasket around the studs? so it seems you just filled the gaps as a precaution... please correct me if im wrong... were your gaps bigger then the ones in my block?
Hi SC,
Good question, as you would have observed in my post on finding water in the oil, we hot pressure tested our RSH block, plus the new LSX-LS7 cylinder heads, and we noticed tiny bubbles of water coming up the stud and the nut, which is why we used Loctite's liquid gasket around each head stud.
However, we also noticed beads of water seeping from the gasket interface between the cylinder bores, and if you think about it, the only way that water can come from under the gasket at that particular point is from the crack between the sleeves.
The sleeves sit on a register [step] and obviously, despite the fact that the sleeves is pushed in [or may because of that] there is a potential leak path between the Aluminium bore and the ductile iron sleeve. I say potential because once the sleeves are in you don't know if you have a "leaker" or not until you hot pressure test it, and hands up, who goes to this time and effort?
To eliminate any possible leak we now scrape clean the gap and fill it with 2 pot epoxy, and scrape flat etc, this eliminates any leak path and also gives the gasket full support across the gap. Just as we now "ring seal" every stud.
Yes it is a "Belt and Braces" approach, but better to be safe than sorry least in my book.
Cheers,
Mark.
#51
My Sleeved block didn't have any gaps either. Ive been running it since 2008. not from ERL or RED
I would really listen to Red im pretty sure has designed a few sleeves for blocks.
I think i talked to dart in 2007 and they said they were sending him sleeves to check out before they ran a bunch off
#52
I really dig when Steve goes into the little details about sleeving blocks
#58
solid rollers dont make that much more power than modern hydraulic rollers.... this was proven by several companies including gm high tech as well as the shop whos building my motor... gained only 15 hp by switching from hydraulic to solid.... in one test in the first article the hydraulic made pretty much the same power as the solid in their 440
http://www.lsxtv.com/tech-stories/en...f7bc05556a75f4
http://www.superchevy.com/how-to/090...ft-comparison/
#60
