Using thin headgasket on 6.2 L92
While I have the heads off, would I be able to take advantage of compression bump even with my vvt cam? How thin could I go? I'm thinking about .030. Cam specs are 214/228 .559/.571 on 114lsa
I think there's more to this equation than just compression. With the vvt cam phasing, ptv clearance needs to be a measured at both extremes of the phaser limits. And you want optimum quench, more than just blindly increasing compression.
I've got to pull the heads of my ls2 that's sitting on a engine stand. I was spraying some stability fogging oil in the cylinders and the red straw shot down #3 cylinder. I think stock gaskets are .052 but I noticed that Cometic offers .040 and .045. I understand quench from hot rodding Harleys and optimizing it made for a clean efficient combustion cycle. Would going with a .040 gasket cause any issues with the pushrods and lifter travel? I could be wrong but I doubt. 012 will cause piston to valve clearance issues with a basically stock engine. I'm not talking about a VVT engine as mine is a ls2. Any input? Thanks
If you are removing the heads anyways, you should measure how much the pistons are above the deck, and order the correct thickness of gasket to achieve the desired squish.
Especially if the heads are already coming off. You have the opportunity to gather true empirical data for your engine, why not just do it right and actually measure how much the pistons stick out of the hole?
Optimal and safe quench in a street engine is about .035" to .040" Getting to this point is WAY more important than any attempt to hike the compression ratio....but if you do hike the compression ratio, it's absolutely essential that you get to this point! Street/strip racers who take their engines apart fairly often will go to .030" quench....but they run 12+:1 compression.
With a stock engine that meant for regular and lasting street duty, you want a .040" compressed head gasket (about .034" quench).
Going any thinner is just silly from a potential cost versus potential benefit standpoint.
KW
