Best tool to R&R LS3 valve springs on the car?
Old 02-17-2016, 11:10 PM
JimMueller's Avatar
Default Best tool to R&R LS3 valve springs on the car?
I plan to swap valvesprings soon although I'm undecided on style. So far as specialty tools for the task, I only have a height micrometer. It will be done with the motor in the car without taking off the front cover. What other specialty tools and accessories will make this whole task easier? I have a friend with a compressor so we can use that if it's easier than the TDC method.
What removal tool works best to access all the springs if I don't want to fabricate anything? Here are a few I found.
Amazon.com: VALVE SPRING COMPRESSOR TOOL LSX LS1 LS2 LS3 LS6 LS7 LS9 LQ4 LQ9 FIREBIRD CAMARO: Automotive Amazon.com: VALVE SPRING COMPRESSOR TOOL LSX LS1 LS2 LS3 LS6 LS7 LS9 LQ4 LQ9 FIREBIRD CAMARO: Automotive
http://www.jegs.com/i/JEGS-Performan...rentProductId=
http://www.phastekperformance.com/20...compressor.htm
http://texas-speed.com/p-2291-comp-c...ssor-tool.aspx
http://www.proformparts.com/product-...ategory_id/171
http://i2.tinypic.com/t5qgt0.jpg
What else will I need besides what comes in the spring kit to properly set them up (height to within .060" of coil bind, etc)... a pack of shims (sizes?)?
Old 02-17-2016, 11:18 PM
elephantrider's Avatar
this is the one we use, along with the compressed air hose in the
spark plug hole. never had any issues.
Old 02-17-2016, 11:21 PM
JimMueller's Avatar
Did you intend to add something else to that post? I don't know which one you're referring to
The following users liked this post:
Jimbo1367 (05-01-2021)
Old 02-17-2016, 11:23 PM
lmao yeah, meant to paste the link lol sorry man..
the comp cams unit -
Old 02-18-2016, 08:35 AM
KCS
Moderator
KCS's Avatar
That's the same one I have. It's really easy to use, adjustable for different LS heads, and seems pretty durable. Even with the heads off the car, I'm probably going to use it over the C-clamp style spring compressors.
Old 02-18-2016, 08:41 AM
yup, we've used it with the heads on and off the car. great tool. easy to use.
Old 02-18-2016, 09:34 AM
JimMueller's Avatar
Is it easy to access the back springs under the cowl with the Comp tool? What quantity of shims should I order and in what thicknesses? Will the Comp valve spring micrometer (I have the silver one bought years ago) be compatible with duals, beehive & conical springs?
Old 02-18-2016, 09:45 AM
KCS
Moderator
KCS's Avatar
Yeah, even under the cowl it's really easy to access.
Shim stack is going to depend on the springs you use, and their installed and coilbind height. There should be kits available with different thicknesses that aren't really that expensive. Not sure if any sponsors have that online but if you call, they may be able to add it to your order with the spring kit.
The older installed height mics could work. The retainer usually sits in a step at the top which throws off the measurement, but in the past I've measured the depth of that step with a dial caliper and added it to my installed height measurement and it comes out pretty close. For the beehives and conicals, there are small OD installed height mics that would be ideals. PAC makes a good one.
Old 02-18-2016, 11:20 AM
TurboBuick6's Avatar
http://www.racingsprings.com/LS-Engine-Tools/sku/354
Old 02-18-2016, 02:30 PM
SHovV's Avatar
I got this one because the typical dual spring tool doesn't work on LS7 heads. Really easy to use.
SHovV's Avatar
It's from Lingenfelter btw
Old 02-18-2016, 07:20 PM
JimMueller's Avatar
I'm thinking of just ordering Tim's tool... some of these prices are outrageous.
Old 04-29-2021, 12:26 PM
Ls3Rx7Party's Avatar
It's been a few years. Any recommendations now on what to use?
Old 05-01-2021, 01:23 PM
cino's Avatar
I got the same Lingenfelter spring compressor from Summit Racing.
Old 05-01-2021, 05:08 PM
01CamaroSSTx's Avatar
Received 1,787 Likes on 1,294 Posts
http://www.lsmproducts.com/lsm_tools...ng_compressors
I have the SC-167 and highly recommend it.
Old 05-02-2021, 12:16 PM
KCS
Moderator
KCS's Avatar
I had a version of that one from Thunder Racing when they were still around. Hated it. You have one had tied up holding the ratchet to compress the spring and then have only your one free hand to remove or install the locks. After two spring swaps, the 3/8” drive hole started to round out.
My go to for swapping springs in the car is still the Comp Cams tool. It compresses both springs at once, leaves both hands freed up to remove and install the locks, and you don’t need a lot of room to use it either.
The following 3 users liked this post by KCS:
01CamaroSSTx (05-02-2021), G Atsma (05-02-2021), vff_jeff (10-25-2021)
Old 05-02-2021, 01:09 PM
I do like that design and over half the cost of the LSM SC-167. Does it work just as well when dealing with high spring pressures also?
Old 05-03-2021, 11:42 AM
KCS
Moderator
KCS's Avatar
I’ve only used it on typical dual spring LS kit with 400-470lbs open but I don’t see a couple hundred more pounds of force being a problem. It’s pretty solid.
G Atsma (05-03-2021)
Quick Reply: Best tool to R&R LS3 valve springs on the car?
