JOHNSON limited travel lifter question
Old 02-22-2016, 03:19 PM
casrak7's Avatar
Default JOHNSON limited travel lifter question
how much preload do i run on this lifter? part number 2116LSR. I sincerely hope that they do a better job of making a lifter than they do answering either phone number that they have......because the customer service sucks *****.
Old 02-22-2016, 03:21 PM
casrak7's Avatar
Default continued....
and yes....I realize that they have an email also.......but I hoped an answer could be found here more quickly.
Old 02-22-2016, 04:16 PM
Havoc40's Avatar
Lol...well there's a 1st for everything. Typically we do very well on the customer service side of things. Can't win them all I guess. Sorry nobody answered when you called....
Anyway, I responded to your email. Every lifter we make is designed to operate at the same preload of .035". The margin for error changes depending on total travel and intended use. For the 2116's stay around +/- .010".
Old 02-22-2016, 07:49 PM
mchicia1's Avatar
Could they be run as low as .015? My zero lash on intake was 7.450. Exhaust was 7.460.
I elected to run 7.500 pushrods giving me .050 and .040 preload, because I didn't want the exhaust to be so tight on preload (I didn't measure all 16 valves, so some could have been even tighter).
Is .050" too much? Seems I was caught in between but I only had 3 sets of pushrods on hand in .025" increments.
Old 02-22-2016, 08:13 PM
Havoc40's Avatar
I'll respond with a little more detail tomorrow, when I'm not using my cell phone. Short answer...running @ .040-.050" preload will not hurt anything! The .015" preload question takes a little more explanation, as it isn't necessarily a "bad" thing either (I'd probably elect to go with .018" which is tough with .025" increments). There are some trade offs, though.
Old 02-22-2016, 08:24 PM
mchicia1's Avatar
Ok thanks, I can sleep soundly now LOL.
Old 02-23-2016, 08:17 PM
93Polo's Avatar
I would be interested to hear more on the trade offs.
Old 02-24-2016, 07:06 AM
06blackGTO's Avatar
Me too. Im pretty much in the same boat at Mchicia1 with my 2116lsr's. my zero lash is 7.500 intake and 7.510 exhaust. So I went with 7.550 since that's what my local speed shop had in stock.
But if I cut down to the 7.525 my preload would by .025 and .015, So Im curious about the trade off's too. Is there a greater chance of valve float running .050 and .040 preload?
Is there a chance I could possibly be hanging valves open with this preload? I know my ptv is prob. getting close since Im running milled heads.
Am I leaving any power on the table running alittle more preload? Is my little heavier preload wearing out my 2116 lsr lifters quicker?
Thanks for any info.
Old 02-24-2016, 09:25 AM
93Polo's Avatar
Is there a chance I could possibly hanging valves open with this preload? I know my ptv is prob. getting close since Im running milled heads.
I am about to be in the same boat as I need to order lifters. Are you running the standard travel 2116s?
Old 02-24-2016, 10:20 AM
06blackGTO's Avatar
yep. I believe the travel on them are .093
Old 03-03-2016, 08:54 AM
mchicia1's Avatar
Would love to hear the trade offs of the shorter pushrod.
Old 03-03-2016, 09:04 AM
Cold Zero's Avatar
These from my thread about pushrod and getting it accurate with limited travel lifters
https://ls1tech.com/forums/generatio...l#post19161232
https://ls1tech.com/forums/generatio...l#post19162511
https://ls1tech.com/forums/generatio...l#post19162525
Old 03-03-2016, 09:09 AM
mchicia1's Avatar
BTR had some used 7.475" for sale, so I bought them. I will try the light preload and report back. I know a lot of the guys on YB swear by a tighter preload.
Old 03-03-2016, 04:27 PM
06blackGTO's Avatar
Yeah. I can't wait to hear. Since I'm on the lighter side now also. Car seems snappier down low since I went lighter preload.
Old 03-19-2016, 07:28 PM
wicked_95z's Avatar
Havoc40, you have quite a bit of interest here. Could you finish your thought please?
Old 03-19-2016, 08:12 PM
juniorssrollin's Avatar
I have the 2116 and came up with needing a 7.535 pushrod for .035 preload. I bought the 7.550 from Tick and all seems well. Valve train sounds like a very smooth sewing machine
Old 03-20-2016, 03:41 PM
mchicia1's Avatar
Never got to installing the shorter rods since my dial indicator needs some repairs. The car has been running great with the 7.500 ones, so it may be a while, sorry. I got a bit burnt out from changing bad seals for the 3rd time, so VCs staying on for a while .
If anyone is interested in the 5/16 7.475" pushrods, $60 shipped.
Old 03-20-2016, 06:26 PM
mchicia1's Avatar
I will say I love these lifters. I have revved over 7k rpms quite a bit because of tire spin in the 1-2 shift with zero issues.
Old 03-21-2016, 11:01 AM
Super Hulk Smash
JakeFusion's Avatar
So I have the short travel lifters. They only have .058" of travel. I have my cold preload set to an average of .034" that will grow to about .028" hot. You want to try to be in the middle of the preload range for the lifter. So Around .045" hot with yours would be fine.
I'd be interested to see what the lighter preload does. I suspect it aids in top-end stability to counteract oil aeration and pump-up issues.
Old 05-25-2016, 12:02 AM
Super Hulk Smash
JakeFusion's Avatar
So I want to bump this. I swapped cams... and I had an extra set of Mantons laying around.
I had .034" avg with 7.557" pushrods before... and now it looks like I'm around .015" avg with 7.572s I had... so instead of buying a 3rd set of Mantons, I was wondering what the trade off was for the .015" preload.
Quick Reply: JOHNSON limited travel lifter question
