If you haven't tought much about the oil galley Barbell check this out!
Old 11-05-2016, 06:42 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default *Updated*If you haven't tought much about the oil galley Barbell check this out!
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 7075 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more! Also available for the new LT1/LT5
Only $26.95 Free Shipping
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 11-06-2016, 06:01 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Pretty cool.
Old 11-09-2016, 06:54 PM
LS1Tech Sponsor
Originally Posted by The Alchemist
Pretty cool.
Thank you!
Christian
__________________
Old 11-10-2016, 07:21 AM
SAPPER's Avatar
Damn, I just got a new OE one from work last week. Decisions!?!?!
EDIT: Ok, I ordered one. Let's go.....It's not here yet???
Old 11-10-2016, 07:41 AM
SAPPER's Avatar
Damn, I forgot to add in the Alignment tools.
Old 11-16-2016, 01:21 PM
LS1Tech Sponsor
Thank you Sapper for your Business! Did you receive it yet?
Christian
__________________
Old 12-03-2016, 05:54 PM
07NBSChevy's Avatar
I may have to pick one up. I use all your alignment tools for the front and rear covers. They make alignment a snap.
Old 12-03-2016, 05:55 PM
TX98Z28's Avatar
I have always wondered what that plug was for, now I know. I'll definitely pick one up for the new motor. It's always the little things.
Old 12-17-2016, 03:54 AM
ondatrack's Avatar
I am glad that I saw this thread. I have your alignment tools that I will be using soon to assemble the two engines I am putting together. I was getting ready to buy two new factory barbells and I did not realize there was a higher quality alternative. I just ordered two of them. Thank you.
Old 12-17-2016, 01:05 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
With less tolerance built into your aluminum barbell, what happens at high temperature when the barbell expands?
Andrew
Old 12-17-2016, 01:39 PM
TURBOLSBIRD's Avatar
Billet aluminum or Billet steel?
Old 12-18-2016, 09:54 PM
LS1Tech Sponsor
Andrew
Hi Andrew,
The oil passage also expands with the Barbell. Also we did an expansion test and took a Barbell that was at approximately 60 degrees and took it up to 220 and it only expanded less then .0005".
TURBOLSBIRD, They are made of 7075 aluminum.
Thank you,
Christian
__________________
Old 12-18-2016, 10:51 PM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
I had my builder put one in my just completed build he thought it
Was a very nice piece as well.
Old 12-19-2016, 11:19 AM
LS1Tech Sponsor
Thanks NAVYBLUE for your business and the good word!
Christian
__________________
Old 01-02-2017, 11:09 PM
Cobranut1's Avatar
Why wouldn't this have an o-ring on both ends?
It seems like that would solve the oil bypass problem entirely.
Old 01-03-2017, 10:59 AM
LS1Tech Sponsor
Hi Cobranut1,
We experimented with the O ring, the problem is that when you slide it in, the oil galley's that come up from the filter and go to the cam are very sharp and cut chunks off of the O ring. These pieces of O ring would clog the lifters and get in the bearings and do who knows what else. When doing the prototype we were lucky we able to fish the pieces out on the several attempts that we tried O rings. That is probably why the factory didn't go with a O ring on that end. So we decided it is much safer to just make a better fit.
Thank you,
Christian
__________________
Old 01-03-2017, 07:55 PM
Cobranut1's Avatar
Makes sense. Thanks Christian.
Old 01-09-2017, 07:33 PM
muleyman78's Avatar
Good info I may have looked past. thx
Old 01-13-2017, 11:14 AM
Senna's Avatar
Question for you Christian
What stops the barbell from traveling back the thickness of the gasket until it hits the rear cover? This would be on the factory barbell or yours.
Is it having fairly equal pressure on both sides of the barbed section?
Old 01-13-2017, 02:09 PM
LS1Tech Sponsor
Hi Senna,
The Barbell does slide back until it hits the cover. Thats why when you pull the cover the Barbell is sticking out about .050".
There is a little lower pressure on the shaft side of the Barbell from the restriction of the oil going through the filter. Thats why the Barbell gets pushed back to the cover and unfiltered oil can get by if its loose. Hope that helps.
Christian
__________________
Quick Reply: If you haven't tought much about the oil galley Barbell check this out!
