Stock LS2 Heads and gaskets.
Originally Posted by 93zm6tally
I know that, but did they get the 10.9:1 from just the flattop pistons?
Not sure about that but were you asking in your original post the bore of the stock gasket or the thickness ?
Just trying to find out the deck height and everything else to run a dynamic compression calculation.
Originally Posted by tanglewood
Well, it was more thickness, but now that you mention bore... The bore is a little bigger on the LS2 that the LS6, so the gasket would be different right? Also, does that mean that the combustion chamber is smaller in diameter than the cylinder? Or are the LS2 heads slightly different than LS6 heads?
The ls2 and ls6 heads are the exact same.
