Texas Speed 402cid LS2 Short Block Special!!
Complete Assembled & Machined LS2 Short Block From Texas Speed!!
Components:
Your Choice Of Pistons:
Diamond -2cc Piston
or
Diamond -15cc Piston
or
Mahle -12cc Coated Piston
Rods:
Scat's New 6.125" LS1 Specific 900hp Rods w/ ARP Bolts
Crankshaft:
Eagle 4340 4" Stroke LS1 Crankshaft
Bearings:
Clevitte LS1 H Main & Rod Bearings
New GM Cam Bearings
* This kit also includes the LS2 components needed to install it into a LS1 vehicle such as:
Front Cover
Timing Set
Cam Sensor
Front Cover
Valley cover
This Complete Short Block Pacakge Is On Special For $3800 Complete!!
Components:
Diamond -2cc Piston
or
or
Rods:
Crankshaft:
Bearings:
New GM Cam Bearings
Front Cover
Timing Set
Cam Sensor
Front Cover
Valley cover
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1Tech Premium Sponsor
We recently did the same basic setup with a large camshaft & 225 cylinder heads. The car made about 540rwhp with stock vette mufflers Dug I'll shoot ya a IM quote
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
You'd have about 6600 with the 225 heads, cam & Cometic head gaskets.
__________________
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
Do you also do complete longblocks to where I'd only have to swap over sensors, accessories, intake, valve covers etc?
We have complete long blocks also It all depends on what heads & cam you want
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Jason,
let me know what up.
i sent you a pm, im getting closer to making a decison
thanks!
Mike
Originally Posted by scalemaster
what size of velves are the AFR's
and flow #'s
and flow #'s
www.AIRFLOWRESEARCH.com
