Chipped my balancer Am I screwed?
Old 08-06-2005, 04:30 PM
robul's Avatar
Default Chipped my balancer Am I screwed?
I was installing my balancer on my GTo after cam install tapping it with the hammer couldnt for the life of me find a longer bolt and a chipped a small piece of the lip. Is the LS1 internally balanced? Do i need a new balancer? Let me know what you guys think
tia
Old 08-06-2005, 05:43 PM
HMFDZ28's Avatar
You should replace it, the motor is internally ballanced but you can still throw off the harmonics of the motor.
Old 08-06-2005, 06:32 PM
Stroker 1500's Avatar
tia
if you chipped it off im assuming you where not using a dead blow hammer. If thats the case you might have done some damage to the thrust bearings. You should really never hammer on a balancer but if you have to use nothing other than a dead blow otherwise you can and most likely will do some bearing damage.
Old 08-06-2005, 06:35 PM
Richiec77's Avatar
The motor is internally balanced, but the balancer/pulley is also balanced to itself. You'll NEED a new one.
Old 08-06-2005, 08:32 PM
SiL3NtXWS6's Avatar
You will be fine until you get a new one. I chipped mine too and ran it for 5,000 miles at 400whp and it was fine.
Old 08-06-2005, 10:16 PM
ace68's Avatar
No I don't think he will be fine I chiped one on a mustang I had a few years back and one day running the motor at some decent rpm's BAAAAAM **** flew into pieces messed up the timing cover, rad., wp, shall I continue. Yours may not spload but do you want to risk it.
Old 08-06-2005, 11:23 PM
Beast96Z's Avatar
I have a new SFI certified ATI balancer I'm looking to get rid of. It's stock diameter and a much better harmonic dampner. Part number 105-917264. You can read about them here: http://www.thunderracing.com/catalog...mid=16&sid=250
Just an option over the stocker. PM me if you might be interested. I'll sell it for half off the new price.
Old 08-07-2005, 02:48 AM
robul's Avatar
thanks dude. I went ahead and put it back together and it seems perfect. I am going to go ahead and order a ASP or march or whatever underdrive pulley i decide I will get the most results from. I would never pay that much money IF i didnt have too but since I have a legitimate excuse to blow 300 dollars on something that will virtually produce no major results I say what the heck
Old 08-07-2005, 02:50 AM
robul's Avatar
I can see where your coming from no doubt.. I went ahead and wieghed the chip on a digi scale i just happened to have laying around.. .3 grams.. I think a lttle piece of the lip wont make the pulley fall apart but better safe than sorry
Old 08-07-2005, 03:34 PM
ace68's Avatar
Yea, you don't need a splosion in dear.
See the thing is you have a chip but are there any cracks, that's the real issue.
Old 08-09-2005, 02:23 PM
bowtieman81's Avatar
I would replace that balancer ASAP. ace is right about the chip possibly causing an explosion, and you can guarantee the sucker will explode at redline. I saw pics of one that blew on an older camaro, looked like a small bomb went off under the hood.
Old 08-09-2005, 07:46 PM
DavidNJ's Avatar
And it is a perfect opportunity to use an ATI damper.
http://www.atiperformanceproducts.co...pers/index.htm
Beast's deal sounded good (about what I did for my race car). And ATI will rebuild them for around $70.
Quick Reply: Chipped my balancer Am I screwed?
