TREX...LS2...ptv clearance..with heads on
OK I am installing my buddies TRex cam in his 06 Gto for him.
Problem is its suppose to be .608 and .612 lift but the cam spec card shows .614 and .619 lift. (Duration is 242/248)
Just wondering what method/s i could use to check PTV clearance with the heads on?
not all trex are the same from what i read
i put the trex in a Lq9 with 243 heads which is basically a LS2 iron blcok setup. no issues its probably tight i put it in and ran it. car is a pure beast...02ss
Originally Posted by TheZaZ
well...got it installed and everything worked out.
We are gonna do a dyno tune on it on the 10th... should be interesting to see what it makes...
If so, how did you check??
