Head swap gasket question?
Putting a set of Patriots on my 1999 z28 this weekend, On the head gaskets what role does thickness play? Can i just pick some up from the dealer or Advanced Auto Parts?
If you want the best power and resistance to knock, get .040" Cometic gaskets from Thunder racing. They will increase compression a bit, while at the same time making your setup more resistant to knock and detonation.
They are pimp, and don't require a retorque like the factory gaskets. I run them.
