LQ4 complete weight
LQ4 complete weight
OK I’ve searched till my fingers are bleeding (see links below) and know someone here can answer this in a minute so here goes. I am curious about the actual weight of a complete LQ4. I know it is 93 pounds heavier than the LS1, but I’m seeing way too many different weights to know what is right.
Bottom line LQ4 (complete), what does she weigh?
Thanks!
Weight difference...LS2 vs 6.0L Iron
https://ls1tech.com/forums/showthrea...ht#post4793745
I measured it at 93 lbs. (difference) - 87 lbs for the ls1 and 180 for the iron block.
(180 for the iron block and 87 lbs for the ls1 block).
LS1 Info and Specifications
http://www.smokemup.com/tech/ls1.php
Out of crate weight approximately 390 lbs.
2001 LS1 vs. 2001 LS6 Engine Comparison
http://www.corvetteactioncenter.com/...06/ls1ls6.html
Total Dressed Engine Weight Auto. - 457.6 lbs / Manual - 497.2 lbs
Worlds First Supercharged LS1 Porsche 911
http://wheeltalk.fancal.net/?p=608
Fully dressed weight of the LS1 is 434 lb.
https://ls1tech.com/forums/showthrea...ht#post3794957
Iron or Aluminum
https://ls1tech.com/forums/showthrea...ht#post3701929
An Iron block weighs 93 lbs more than an aluminum block
Links
http://www.team.net/sol/tech/engine.html
Thanks!
Iron or Aluminum
Links
OK I'll answer my own question. I'm saying LQ4 = 527 (434 + 93). Reality might be a scratch lighter.
Couple extra links.
Engine weight???
https://ls1tech.com/forums/showthrea...ght#post446748
complete engine is around 400lbs
Need to know stock LS1 Weight minus accessories
https://ls1tech.com/forums/showthrea...ls1#post506347
I believe its 390ish.
Couple extra links.
Engine weight???
Looks like I was off by seven pounds. To help out the next guy searching for the actual weight, it appears that the right number is 520 LBS per Will Handzel’s “Chevy LS1/LS6 V-8s” book.
