Cam sensor Harness will not plug in to LS2 sensor????
Old 10-09-2007, 11:08 AM
KWIKKAR's Avatar
Default Cam sensor Harness will not plug in to LS2 sensor????
Help me out guys. I'm finishing up my 402 LS2 with twin turbo car, and I bought a P&P Harness for the Ls2 cam sensor but I tried to plug it in and it wont fit. There is a little notch on the Sensor that is not allowing the harness to plug in to it. Is this right.\?? This there a different sensor I need or what. Here's a picture of mine(first) and then I picture I found on here (seocnd). Also is the 4" bracket needed????
Old 10-09-2007, 11:11 AM
ONEBADWS6's Avatar
Just goto Radio Shack, buy some wire, sodering iron, shrink wrap and some wire cutters. 5 min latter your done.
Old 10-09-2007, 01:01 PM
blkvett01's Avatar
You need the second picture, it will not plug in the first one. It takes the drop down to make it match up with your plug and play!:
Old 10-09-2007, 03:49 PM
KWIKKAR's Avatar
Ok thats what I was hoping for. Anyone know a part number or if its on a spec year model car.???? I can order threw dealership. thanks
Old 10-09-2007, 03:58 PM
Randy WS6's Avatar
What blkvett01 said, Will not work with out the adapter harness in the second pic.
Old 10-10-2007, 07:56 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Part number for that pigtail is 12593593. Should be about $15!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 10-13-2007, 07:27 AM
DRIVER456's Avatar
where did you get that LS2 timing cover? It looks like you can get to the cam without taking the cover off..............Paul
