427 mockup pics
https://ls1tech.com/forums/showthrea...92#post6842110
Looks like a similar build to yours . I plan on building a similar engine , mines only going to be a 408ci though with a F1 Procharger
You should consider having the intake manifold ported . Seen good gains on the LS7 engines ,L76 intake is similar so it should show some gains . Good luck .
Looks really nice! I don't want to burst your bubble but like stated above.....550 to the rear wheels will be tuff with an auto. I have a built 427,ported LS7 heads and intake with an auto in a Trans Am and I am seeing 535 to the wheels right now. I am running a Ford 9 inch though which robs quite a bit but I just don't want to see you get too attached to the 550 RWHP. It is possible but it will take alot more then you think!Traver
