5.3 PRC Stage 2.5 with MS3?
Old 12-26-2007, 01:17 PM
sedanman's Avatar
Default 5.3 PRC Stage 2.5 with MS3?
Does anyone know if PRC 5.3 2.5 heads will work on a stock ls1 with a MS3 without flycutting the pistons? Also what kind of compression does a set of 5.3 heads yeild on a stock motor. Thanks.
Old 12-26-2007, 01:39 PM
5.3LJimmy's Avatar
Static compression is 10.7 if the heads have a 63cc chamber(which I think they do). Best thing to do is call or email Jason at TSP and ask him to verify the combustion chamber volume and if it will work with the MS3. It seems like I remeber seeing a thread that said it will clear, but I would ask Jason to make sure.
Old 01-02-2008, 10:55 AM
Eurospec2's Avatar
If ordered together they set up the heads so no flycutting is required, i run this combo and i did not flycutt, works great
Old 01-03-2008, 06:37 AM
PBMFIsMe's Avatar
Check the Dyno results section. There are a ton of guys running that combo and making incredible power with it.
Quick Reply: 5.3 PRC Stage 2.5 with MS3?
