Marking Ti rods for removal
This is going to sound really dumb but I want to ask. I am disassembling my LS7 and I want to mark the rods and caps to keep them together and oriented. Old days I would use machinists stamps to gently stamp a number on each half of the cap. Can I or should I do that to these rods? Or is there another method I should be using? GM does not specify.
Thanks!
Thanks!
I mark mine w/masking tape and sharpie pen, that way on reassembly I double check myself to make sure what came out is going back in the same place.
No question is a dumb question, unless its one you don't ask(and wish you did). $.02
If you can avoid it DO NOT stamp or etch Ti. It is an extremely notch sensitive metal. It is ALWAYS preferable to use a non destructive marking method such as a sharpie,tape,grease marker,etc.
If you do happen to nick or scratch a Ti rod do your best to "polish" it out with a very fine abrasive and then clean thoroughly.
